Since the Cerbo GX only has digital inputs I was investigating the potential of using the Multiplus optional connections instead but all I can read from the manual is the following:
4.4.5. Programmable relays
The relays can be programmed for all kinds of applications, for example as a starter relay for a generating set.
4.4.6 Programmable analog/digital input/output ports
These ports can be used for several purposes. One application is communication with the BMS of a lithium-ion battery.
Where can I find more instructions on how to use the digital in/out ports?
