britinusa avatar image
britinusa asked
MultiPlus will not invert unless engine running
Victron Multiplus 12/3000/120/50
Scenario:-
Boat away from the dock. Engine off, need to run the inverter but it will not switch from "OFF" unless we start the boat engine. After a few moments above idle rpm, the Inverter will switch on then everything is fine. If I turn the inverter off and later try to run the inverter again, same thing - have to start the engine. Once the inverter is on, then I can shut down the engine and everything works as exepected.
I'm guessing it's a programming issue ( not using any clever Code Red features at all )
It's as though some setting is recognizing that the battery voltage is too low to run the inverter but the batteries are typically around 99-100% charged ( 300Ah LiFePo4 )
Any ideas?
( had to choose Multiplus-II as Topic as Multiplus was not an option)
Multiplus-II
kevgermany avatar image
kevgermany answered ·
There's a setting in the multi fo battery voltage. You'll need a MK3 to usb adapter and ve.config (free download) to access it.
britinusa avatar image britinusa commented ·
I figured it would be something like that. I have MK3 to USB and ve.config I just don't know which setting. :(
JohnC avatar image JohnC ♦ britinusa commented ·
@Britinusa
In the 'Inverter' section of VEConfig there's 3 Voltage settings. Do they suit? A wild guess is that the Restart one is too high.
britinusa answered ·
Thanks John, I'll check that at the boat tomorrow ( it's 30mins away from home ). I like your wild guess :)
Thanks @JohnC, that was it.
I use the MK3 and VE-Config (windows laptop ) and found the Inverter settings. Changed the 'DC Low Input Restart' value from 13.8v to 12.8v.
Battery bank is 3 x Chin 12.8v LiFePo4 batteries - Parallel ( each battery is 4x3.2v Cells )
Tested the system after 24 hours and it switched into Inverter mode within a couple of seconds.
Yes, I saved the settings after making the changes.
Thank you guys!
