The situation is a EasySolar II GX 24/3000/70-50 in parallel with a Multiplus II 24/3000/70-50
Connected to VRM portal.
Is it possible to add an extra display, color control, etc. here?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
You can add a Cerbo, CCGX, etc to the system by disconnecting the one internal to the EasySolar. You will then not have a local display however.
CCGX is not recommended for new installations. It will not ever support gui-v2 for example.
You could use a (old) phone or tablet to connect to the remote console locally.
I think "enable remote console on LAN" is always enabled on an EasySolar-II - I don't have one here to check.
That's exactly what you see if you use the local IP to connect to the GX device.
If you want to get closer, this thread:
https://community.victronenergy.com/articles/5930/disable-hotkeys-in-venus-remote-console-on-lan.html
describes how to remove the buttons.
There are also settings in some browsers to run in "kiosk" mode that hides the menu bar, etc.
119 People are following this question.
