System: Multiplus II GX 5000/70 + Pylontech US5000
Software: v3.30~13, ESS assistant configured (see screenshots below)
Connections: grid on AC IN1, consumers and Enphase system on AC OUT1
Grid: the Netherlands (EN50549-1:2019), configured in both Enphase/Victron
As soon as the grid is disconnected, the Enphase system stops delivering power. It tries to send a bit of power (50-100 Watt, see the graph below), but it turns off each time.
The graph starts and ends with grid power on. The test was deliberately with only some solar power (~300 Watt), but with more solar power, the same problem occurs.
The Enphase system is fed with 230 Volt and 50 Hz by the Victron (measured with an SDM120 energy meter), so everything is seemingly fine.
It was suggested to change the grid profile of the Enphase system to one of the GB profiles because it was said to tolerate a less perfect sine wave, but that didn't help to solve the problem.
I've checked the settings already many times, but so far, I haven't found a solution. So, any suggestions are welcome.
