Hi guys,
I searched this forum back and forth and could not find any possible solution
and can really use your help with troubleshooting my MultiPlus unit.
I can not get it to start inverting. Without grid power, the AC-out line does not have voltage.
Note: charging works fine.
If I turn off the shore power (50A),
Multiplus starts beeping,
The "Inverter On" light is solid green
No other lights are on or blinking
I do not have 120v power on AC-Out line.
If I turn on shore power after that, it takes a few minutes for Multiplus to start supplying power back to the lines. Is it normal to take that long?
During those few minutes, it kept beeping.
No errors or alarms are in VRM except an expected "Grid power lost" alarm.
Do you have any ideas on how I can troubleshoot this?
