Dear friends! Please advise a trusted manufacturer of wind turbines (1-5 kW) whose products you have used in conjunction with Victron Energy equipment. I am doing off-grid solar power plants using MPPT controllers and MultiPlus or Quattro inverters. Batteries are mainly installed AGM with a voltage of 48 volts or LiFePO4 from BYD with a nominal voltage of 51.2 volts. It is important for me to be able to see the production of a wind turbine on the VRM-Portal. I would be grateful for any recommendations from people who have done this. What configurations did you use? How did you connect the equipment? How did you set up monitoring through the portal? Thank you so much!
