juanc avatar image
juanc asked
Is it possible to conect up 3x90W solar panels parralel with a Kestrel windturbine (+/-40A) to the MPPT 250/60
Hydro and Wind Power
Kevin Windrem avatar image
Kevin Windrem answered ·
I would use separate charge controllers for the solar and wind turbine so they don't fight each other and can both contribute simultaneously to load and battery recharge.
If you try to connect both solar and wind to the input of a single charge controller, one source will probably dominate the other. The result is you would not get as much energy compared to using separate charge controllers.
