mendok avatar image
mendok asked
Wind inverter
Hi all
I have a victron MultiPlus-II, cerbo gx, 48v batteries and wanted to connect a wind turbine 48v 2000w 3 phase to the system.
I have a sun 2000 gt with a dump load and it has ac output.
Was wanting to know if i would connect the sun 2000 to the MultiPlus-II ac out??
Thank you
Any help would be GR8
Hydro and Wind Power
Paul B avatar image
Paul B answered ·
IF you did this then the 2000GT would have to operate like a Grid Tie Solar Inverter. no ac then its off and when ac returns it graduly increases power, plus plus it has to be able to be controlled by frequency shift, then you MIGHT have a chance.
you would also need to be able to control how and when it shuts down ie
the loads low and the batteries and full and the grid is off, then the 2000gt must be told to shut down or reduce output , this is done with a grid tie by raising the frequency
the correct assistants would have to be setup in the Muliplus/quattro
https://www.victronenergy.com/live/assistants:pv-inverter-support
also the wind units in put must NOT be higher than the size of the inverter.
This is not a recommendation form victron and you would need to test it and see how it proforms, ALL risk as to damage to diferant products would be at YOUR RISK ONLY
