I have a Victron MultiPlus C 12/1600/70-16, and are having problems with it accepting my generator, Honda 10EU.
I have followed instructions from Victrons FAQ: What to do when a MultiPlus does not accept generator power.
I have disabled UPS function and enabled Weak AC input. I have also activated the dynamic current limiter and the Power Assist and tried to have a ohm load on the inverter. However, the Multiplus is not accepting the generator, all load are going from the batteries. When I put load on the multiplus it is taking all load from the batteries and none from the inverter. When I am setting the multiplus to a charger only mode it is not functioning.
Can anybody help?
I see from the VE config that the generator Frequency is 50,1 Hz and the voltage is 239V which should be fine, see picture below.
Thanks.
