Hi, I have 3 phase system with Quattro 48V/5000VA, 2 Victron LiFePO4 batteries( 25,6V/200Ah), running ESS with Fronius ongrid inverter connected at the AC input of Quattros. The meter is Carlo Gavazzi EM24(with CTs). The problem is that in case I'll set "Fronius zero feed in" to ON, PV production is reduced to the necessary load, but even when it is a lot of sun, the charging battery is limited very low or zero. In the case I switch off the zero feed in, it is working well, but I don't want to export a lot of power into the grid. It seems that the smart meter is faster than Quattro and first is ordered zero feed in and after that is not enough power to charge the battery.
