giraaf avatar image
giraaf asked
Multiplus II Detected Battery Capacity is incorrect
Hi everyone,
I have noticed after enabling Dynamic ESS that the available/installed battery capacity showing on the Multiplus is incorrect. I have checked my ESS settings and made sure everything is correct there (200AH) but it still shows as 240AH installed/available.
Where does this reading come from? The BMS or is it calculated based on current/voltage etc.?
I have 2 x BSL 5.1kwh (100AH) batteries
MPPT 150/100
Appreciate the inputs!
Regards.
Multiplus-IIbslbatt
@GiRaaf
It comes from.the BMS if you are seeing it on the GX.
