sparky54 avatar image
sparky54 asked
Staying connected via WiFi to Cerbo GX
I have an issue with staying connected to my servo GX once the sun goes down. I lose my Wi-Fi connection for some reason and then I have a hard time getting it back in the morning until late morning early midday my Wi-Fi connection is good to the servo GX, please help
cerbo gx
David avatar image
David answered ·
The thought that comes to mind is the power to the GX and/or the WiFi Router is connected to the LOAD output of a solar controller and that is configured to be active only when there is a PV voltage present.
7 comments
sparky54 avatar image sparky54 commented ·
Thanks for answering David. I will look into that. Excuse me for asking silly questions, but I am not super versed in this stuff. Should the power source be hooked directly to the batteries? And not to my main battery terminal hub?
ejrossouw avatar image ejrossouw sparky54 commented ·
Where is the Cerbo powered from? Best practice is to power it directly from the battery as David suspects it loses power if connected to e.g. a MPPT load side.
James Trotter avatar image James Trotter sparky54 commented ·
Unless there are diodes involved for some unknown reason, the entire "load" side of the system is basically a common positive/negative rail straight to the battery, no? This answer doesn't make much sense to me.
David avatar image David James Trotter commented ·
if yours was a reply to my answer, than "the entire "load" side of the system is basically a common positive/negative rail straight to the battery, no?" is NO, it is not. the LOAD on a solar controller goes through the controller and if a Victron solar controller can be turned on and off by various methods.
I don't know if the OP has his Cerbo and/or wifi router conencted in this way, but it is a scenario that could create his problem.
sparky54 avatar image sparky54 David commented ·
So I took my positive and negative power supply for the Cerbo GX and took it straight to my batteries today, I also uninstalled my Cerbo GX and opened it up to see if I was having issues with the Wi-Fi antennas, It turns out I have the newer version where they moved, the antennas to the sides vertically. So things were going OK through the day and then around 6 o’clock I got disconnected again and I have not been able to get reconnected all afternoon and night even if I go out there and stand right next to it.
pwfarnell avatar image pwfarnell sparky54 commented ·
Do not forget to check the router power supply aswell.
ejrossouw avatar image ejrossouw James Trotter commented ·
@James Trotter The load output is configurable and it could have disconnected as a result of e.g. a voltage drop that turned it of when the solar stopped producing. I am also interested to know what type of battery, what are the daytime vs sunset voltages measurements, does the cerbo lights still show activity at night etc. etc.
sparky54 answered ·
I changed the hookups going straight to the batteries now. So here’s 2 things I have for y’all. So my system is in my garage. My garage is not attached to my house, I have a Wi-Fi booster/extender on the outside of my house facing the garage. Normally, I have absolutely no issues with this with my TV that I have out there which I have Roku on, as well as my phones, however, when I close my garage door, which is thin aluminum, I lose signal. Then the only way to reconnect to the Wi-Fi I have to unplug the power source from the Cerbo GX And then it will reconnecttothe Wi-Fi rinse and repeat every day. I understand that I need to do some thing about keeping the Wi-Fi connected, but why do I need to disconnect the power from the Cerbo GX every time in order for it to reset?
chrigu avatar image chrigu commented ·
Theres “Reboot device when no contact” option in the GX device's VRM menu
(Cant add a screenshot since my GX has no connection, oh the irony)
