drogos avatar image
drogos asked
Filax 2 pops fuse
Hello, I have now tried 2 different filax 2 in three different installations. Grid power connected to priority one and victron inverter on the other. Seemingly randomly in all setups the grid fuse pop about 50% of the time when swtiching back to grid power from inverter backup. Is this just how it is, or could both units be broken in the very same way?
gridinstallationvirtual switch
Alexandra avatar image
Alexandra answered ·
@Drogos
What size load is being switched? (And load type?)
What size fuse is blowing?
4 comments
drogos avatar image drogos commented ·
Tried everything from a single computer, to a home cinema and server rack. So, various tests between 100W and 2kW
Grid side fuse is 16A, solar side fuse is 10A
Alexandra avatar image Alexandra ♦ drogos commented ·
Do you have fast blow fuses? And why fuses and not a breaker?
What inverter are you using there? Sorry for the questions. Any theories would be total shots in the dark without more details.
Only thing i can think off offhand is maybe a neutral live swap somewhere?
drogos avatar image drogos Alexandra ♦ commented ·
That might just be a translation thing, sorry. It is breakers in proper English. Fully GFCI I believe they are called in English? Those are on the grid side. On the solar side, I have used regular breakers without the ground fault detection thing.
Tried three different inverters, one 48/3000 Phoenix, one 48/8000 Quattro, and one 48/800 Multiplus.
In the old fashion lands of Norway we still use IT net, which does not have a neutral wire.
VE Configure/Virtual Switch
Ignore AC input using the Generator Assistant
