Sorry if this has already been asked.
Going trough the Multiplus II manual, I cannot find a clear information about the maximum output current supported by the 10kVA/230 model in PowerAssist mode.
The manual:
AC-out-1 The AC output cable can be connected directly to the terminal block ‘AC-out’. From left to right: “N” (neutral), “PE” (earth) and “L” (phase) With its PowerAssist feature the inverter/charger can add up to 3 kVA (that is 3000 / 230 = 13 A) to the output during periods of peak power requirement. Together with a maximum input current of 32 A, this means that the output can supply up to 32 + 13 = 45 A. An earth leakage circuit breaker and a fuse or circuit breaker rated to support the expected load must be included in series with the output, and the cable cross-section must be sized accordingly.
Is this only for the 3kVA/230 model? What are the values for the 10kVA/230 model?
Can I assume that the 10kVA model can handle 50A (AC Input) + 43A (Inverter) on the AC-OUT-1 and AC-OUT-2?
Thanks!
