Hi all,
i have something wierd going on.
DC Feed-in on = voltage goes to +0.4v ( what is normal in the manual )
so when i setup my ve.config charger absorption voltage to 56v and DVCC 56v it goes to 56.4v a 56.8v ( is to high for me , lithium bateries)
i want to charge with 56v max. and do DC feed-in
( i have one installation , where there are lead acid batteries , and the voltage stays at 60v even with DC-feed-in on.. but what the hell...)
so i played around , lowered the DVCC voltage to 55.6v , still goes to 56.4v a 56.8v
than i changed the ve.config charger abs. voltage to 55.6v and what do we see... yes 56v ( w00t w00t ), you think all is ok.
BUT than when i disable DC-feed-in .. DVCC still on 56v and ve.config charger on 55.6v == indeed goes to 55.6v abs.
so for me the DVCC does not work.
or is it my wierd brain ?
https://nextcloud.kg666.org/s/zJXYQLcE5e9fRSk
https://nextcloud.kg666.org/s/FnRm3iHMQKgeqK7
https://nextcloud.kg666.org/s/dqJejk3gFqb6w9L
P.S. the system iam talking about , where the voltage stays at 60v ( everything setup @ 60v, ve.config charger / DVCC ) and DC-feed-in enabled = is a 3 phase multi-plus II 5000 system.
my system is a single quattro 8kva ( will change to multi-plus II 5000 later )
