Please help me with grid set-point.
I understand that feeding 'grid set-point" with value 100 will work in such a way that inverter will consume 500W and the devices on ACout will folow 600V, right?
And when I read " Venus system|Grid L1 (W)" and send the value to "Grid set-point" all the power will be from the battery?
the problem is that it doesn't matter what I send to grid to-set it just not generate flow from battery.
I spend few hours on it, checking manuals and youtube videos and it not working.
I think that in Settings>ESS should be some options, but there is only "No ESS Assistent found"
can you help me?
