mfred68 avatar image
mfred68 asked
MultiPlus-II gone into Passthru mode help please
Not sure what's going on, I have a multiplus II and 10kw of solar and 40kw of battery storage, yet yesterday the system started charging the batteries from the grid at 4kw, even though there was plenty of solar production. The batteries were at 40% and minimum soc was set to 25% in ess mode, with optimisedwithout battery life. I turned the whole system off in the hope to reset what ever went wrong, but now the multiplus is going directly in a Passthru state and only switches to inverting if I turn off the grid breaker.
The batteries are still charging via the mppt, so not sure what's gone wrong and why.
Multiplus-II
nickdb avatar image
nickdb answered ·
Have you checked 10.4 Q4 here for the common causes? https://www.victronenergy.com/media/pg/Energy_Storage_System/en/faq.html#UUID-169dbd85-4b6f-814b-33c2-9fa77a6973d2_section-idm4628123204859232885885561444
Your inverter is off in that pic but has loads, so do you have meters? I would check the multi/meters are all properly connected.
mfred68 answered ·
I've got no meters. I basically had to reboot the system, now it's working again, and the inverter now says external control, not sure what that means but it's working again. Yesterday when it decided to charge from the grid, the inverter said "recharging" but why would it have gone into that mode?
Typically when the battery is below a set theshold that forces a recharge. Could be a comms or battery issue, both situations that can cause this state.
Tough to say without a detailed setup and configuration.
mfred68 avatar image mfred68 nickdb ♦♦ commented ·
The battery never went below the set threashold, it was charging via solar all day, until this happened. Worst part was that I couldn't stop it unless Turing the grid breaker off.
What information should I upload for you to see if I have any settings wrong?
