I've been having issues with my smart BMV SOC ever since the solar system was installed by my travel trailer dealership. I had a look at my battery and noticed there were two wires connected to the negative terminal: the negative battery connection from the shunt, and the negative wire running from my MPPT solar chage controller. I moved the MPPT negative down to the loads and chargers side of the shunt.
Now the smart bmv is showing my battery's SOC at 100%. But the output power reading is showing a positive value rather than a negative (the solar coming in minus the actual load). What have i done wrong?
