Installing an Orion XS on a boat to charge my lithium house battery. I also have an AGM starting battery hooked to the alternator. If the max output of the XS is 50 amps, what happens when the motor is at idle and the alternator is not putting out 50 amps? Will the XS pull back the amperage to what is available, or would it continue to pull 50 and potentially pull amps from the starting battery? Or is it possible to program something?
Thanks
