Hi there,
I have a MultiPlus 12V/3000 with a Cerbo GX. U have discovered that the AES will not enable if certain devices are plugged in, despite the power level being below the required threshold.
The devices that cause this are KithchenAid blender, laptop charger and Victron BlueSmart IP65 battery charger. If these are plugged in, then AES will not engage even when the power draw is less than the threshold set.
I am curious to understand what these devices have in common that prevents AES?
Thanks,
Corey
