Description of failure: Orion XS after two weeks of work start loosing Ve.Direct signal.Ekrano GX can see it, but Connected Status changing from Yes to No , and No to Yes every 5 seconds. I tried to re-install Ekrano GX OS with full reset to default settings I tried to manual update Orion XS firmware to 1.03 (again)
I tried to use different original Victron cables : 10m(inside boat covering) and 5m (direct to device)
I tried to use different Ve.direct connection : 1,2,3 on back of Ekrano GXIn same system I have Smart Shunt with Ve.Direct connection (10m) and it's works fine.
Any ideas ?
Br
Ton van der Reijken
