nicholas-le-maitre avatar image
nicholas-le-maitre asked
Victron Smart Solar bricked
Hi there
I connected to my Smart Solar unit, and noticed there was a firmware update, which I applied. Since then the icon for the device in the Victron Connect app has changed to a small black rectangle with some text and the options page with the MPPT charger profile settings has gone.
I can connect to the device using the app, but it only take me to a basically static page which looks like this:whatsapp-image-2024-06-16-at-151755.jpeg
I have tried updating the Victron Connect app to the latest version, I have removed and added the device from my phone. I cannot reapply the firmware or factory reset the device.
Any help would be appreciated.
fault
Alexandra avatar image
Alexandra answered ·
@Nicholas Le Maitre
That is the Bluetooth icon. So it seems something went wrong.
You get that one when the Bluetooth interface needs updating as well. But it seems that is not the issue here.
Do you see anything via the instant readout?
Have you tried the good old fashioned power cycle?
Disconnect solar
Disconnect battery
Wait a few minutes
Connect battery
Check with app
If working + connect solar.
If not working that is a warranty return.
nicholas-le-maitre avatar image nicholas-le-maitre commented ·
Thanks! The power cycling worked! Everything is back.
2 Likes 2 ·
Faults with Victron equipment are best discussed directly with your dealer - this can be formalised with this support request form.
