I'm trying to charge a fairly small (only 10Ah) LiFePO4 starter battery from my house battery using the Orion XS. The absorption voltage is 14.4 and the float voltage is 13.5. Upon turning it on it's doing a Bulk charge for a short period (let's say 10 seconds) at the configured charge current (30A) but it then switches to float when the battery reaches approximately 13.9 volts. And it's using 13.3 volts for its float voltage where it stays indefinitely.
It's as if the configured absorption, float and storage voltages have no meaning. I've for example tried to set the float and storage voltages to 14.3 volts but the effect is the same. It goes from bulk to float using 13.3 volts.
