max9800 avatar image
max9800 asked
feed-in excess Multiplus 2 wear
I would like to know approximatly the difference of wear if I send to grid the full excess of sun
instead of only compensate home comsuption (means max 2200w, instead of 200w)
My installation is a MPPT 250/60 and a Multiplus 2 3000/48 and Pylontech US3000
The Multiplus is used in ESS mode with Curent sensor with only AC IN connected
I whant to charge an Electric car without consumming on the battery, mean connect the Car charger before the Sensor of the multiplus
So I need to send all the excess (at least 1800W) of sun to the grid to use the charger with the sun
What I heard about PV converters life is :
Main inverters life max is about 10-15 years
Micro inverters life max is about 15-20 years
Multiplus life max is about 20 years (some people say more if it's used well ??)
Thanks
Maxime
Multiplus-II
max9800 answered ·
Hello nickdb
I have only one installed
If I understand you mean no matter if I limit or not injection in grid about the lifetime of the Multiplus, I wondered his life was more than 10 year, I'am ok about the 20 years is too much but some people in autonomy mode can reach arround that
I'am not expecting this but at least a life between main inverter and micro inverters
For the moment I'am only injecting in the house, so 50W-100W idle and 1500W from battery or 2200W from solar when dishwasing / cothwasing... for exemple
If I set 1800W feed-in excess, it will be in nices days few hours per day at this power
I'am agree about temperature, but I don't know even if temperature is "ok", I think mainly the transistors and capacitors will wear faster because they are more solicited
Maxime
Don't worry about using it to its design spec, you won't damage it. There are many built in protections.
We run them in a hot climate in demanding conditions and they hold up well.
max9800 avatar image max9800 nickdb ♦♦ commented ·
Thank you
So i will manage the feed-in excess maybe at the power of the EV charger
and play with modbus to get the datas
Maxime
nickdb avatar image
nickdb answered ·
There are no guarantees, and it often is affected by temperature.
All components wear.
Victron offer up to 10-years of (optional) warranty, so that is an indication.
Personally anything beyond that would be a bonus, and I would be replacing my own by then as the batteries are likely to be tired, and parts may be an issue.
If you have a parallel set, replacing one will be an issue, as a new unit may not play well with the other.
They are designed to work and if used in their spec should serve you well.
You are more likely to run out of ability to use new features, software etc long before that, but I wouldn't have an expectation of 20 years.
