Hi, Thanks in advance. I have VW T5 with 180w solar panel > MPPT 70/15 smart solar > which feeds to a leisure battery.
Using the Load terminal on the MPPT I am charging my power station. This is working.
However, the power station is taking charge from the solar panel AND the leisure battery at the same time.
There maybe times when I want this to help speed up the charging process but is there a setting in the Victron app which I can set and only charge the power station via the solar panel. and leave the leisure battery to charge the fridge etc?
Or have I not set up correctly.
regards
Jason
