Any solar sherlocks out there can help? It is as iff my solar controller is throttling the current from the panels. much appreciated:
My setup
- RV
- 400ah= 4x100ah Battle born LifePO batteries
- 300w = 3x100W Renogy solar panels mounted in parallel
- 100/30 solar controller, multiplus inverter, smartBMV
- 2 year old system
The event
- On June 11 had a deep discharge on my RV for a couple days. Plugged the RV back in to shore power charged back up easily.
- Since then max watts from solar is around 30watts. Previously would get to 110watts easily at mid-day.
What I have checked
- VOC/Isc on Renogy panels it is 21v/4.8amps -- not too bad. so panels are good
- tried rebooting MPPT 100/30 controller
- Checked all my connection to make sure not loose
- Checked the fuse between solar controller and battery, no problem
- Checked all my Victron settings setup for LifePo Battleborn batteries. Looks good
Photos
