Hello, I got a Lithium 16 cell battery. I use MP battery monitor at the moment and have standard settings and ESS:
Problem:
-The SOC is at real 20% from the BMS but here it is:
-Means it drops until low voltage alert with 47V but still has 85% SOC. What configuration did I do wrong?
- Whatever I do, i can load only with 500W max, although I do not limit charge power. What is wrong here?
Thank you
