Hi experts
Im close to get my system running, but there are some issues..
Set up:
Fronius Symo 7.0
Multiplus ll 48V, 3000
Cerbo GX
Display
ET340 smart meter.
I can see the Fronius PV om the display, so thats fine.
The problem is the Multiplus keeps charging from the AC grid. I would like the Multiplus ll to only charge when the Fronius is producing. The power consumption is like 300W when in float mode, so thats bad business. On the display I can change to inverting, but its only “feeding” the grid with 42W. The plan is not to do this manually
So there must be some settings I havent seen? (Disable charger, assistents or?)
Hope you can help and thanks a lot.
Cheers Carstens
