Hi there, I need the AC input current to remain around 1A. Thanks to the reading of this Q&A I found that by deactvating PowerAssist I was able to set the input current under 6A. When the Multiplus is only charging it works fine, the 1A limit is respected, but when I switch on my 2.2kW waterpump it goes much over 1A. How to remain under the limit once the Multiplus goes from charger mode to inverter mode? Thanks
