Hi guys, I have a VictronConnect multiplus 2 12V 3000VA that is hooked up to two Ultimatron 150Ah lifepo4 batteries.
I have set the absorption voltage according to the battery specifications to 14.6V. Nevertheless the BMS kicks in at around 14.2V and stops the charging the process. All the cells seem to be pretty good balanced.
The multiplus stays at 14.6V and does not drop down to float voltage (set at 13.8V).
The batteries are new, do they need to get a few cycles until they reach full capacity?
thanks in advance
br lukas
