I totally understand why the AC-cables at Multiplus II in parallel use must have the diameter / length.
(same resistance for having same amount of energy going through each of them)
But unfortunately I do NOT understand, why this should be at DC-side to the busbar (that directs to the batteries) also.
Said with easy words: The Multiplus II pushes the energy into the cables to the bus bar when charging with the quantity they should push, and sucks the energy out of the busbar / batteries in the quantity they should, why does different cable diameter or lengths make a difference?
Thank you very much
Best regards
Johannes
