johannes123 avatar image
johannes123 asked
Multiplus-II 48/5000/70-50 Transfer switch 50A - short overuse possible?
can someone please tell me, as I like to buy a 3 phase set of Multiplus-II 48/5000/70-50:
What happens when using Multiplus-II 48/5000/70-50 and the power at transfer switch gets higher than the 50A that is listed in the datasheet, is there any protection?
- a real fuse
- or shut down because of electronic measurement
- or will it also run with higher power sent trough the transfer switch
Is there any information available whether a short time higher power consumption trough the transfer switch is acceptable?
And 2nd question:
Does the transfer switch 50A mean only the transfered power to the attached power consumption devices, or does it also inlcude the 70A charge power of ~56V battery pack, that might be about 17 Ampere at 230 volts?
So 50A = 50 A for attached power consumption devides
or 50A = only 33A for the attached power consumption devices while 70A charging the battery
Or would the Multiplus-II decrease the battery charging when it detects that more power for attached power consumption devices is needed?
Best regards
Johannes
Multiplus-II
jeanmarie avatar image
jeanmarie answered ·
you have 5000VA usable from DC->AC converter (from batteries)
+ 50A (11500VA) usable from the grid through the transfer switch (if your grid contract allows it)
Total = 16500VA for connected loads on AC Out1+ AC Out 2
as long as the grid is present, of course.
And it's the measurement of the total power that will trip the overload alarm if it occurs
daniel-feist avatar image daniel-feist commented ·
If there is a 60A load on AC-OUT1, will the inverter automatically invert 10A (from batteries) to ensure only 50A via the transfer switch? Is this PowerAssist? My understanding though, is that PowerAssist isn't available with ESS, correct?
johannes123 answered ·
Hello @jeanmarie, thank you very much for your answer.
Please allow 2 question to check whether I understand right:
There is NO Transfer Switch power > 50A allowed / possible, the system will shut down if > 50A power is reached at the Transfer Switch.
But if there is a peak need > 50A / 11500VA power consumpton on togehter AC out 1 and 2, then the Multiplus II will use the battery to increase to about 71,74 A / 16500 VA power that is used by AC out 1 and 2.
And as bonus: In the techical details is written: Peak power 9.000 W.
Does it mean that the max. power consumption of AC out 1 and 2 can be 50A + 39A = 89A for a short time?
Hi @Johannes123
yes you understood it right.
Just keep in mind that "a short time" is for the startup of motor for exemple it is not intended as "some" seconds
