am planning to use the multiplus 2 in a ESS using Valance U27-12XP lithium batteries.
These batteries have their own separate BMS, and this BMS controls contactor outputs. A Charge/Discharge and a charge control contact
The Charge/Discharge contact wil connect or disconnect the batteries from the Multiplus in case of a Failure.
The charge control contactor operates based on the value of VCell_Max. If VCell_Max > 3.8V the contactor output is disabled. If VCell_Max < 3.75V the output is enabled again. In this way the charge control contactor output will pulse off/on based on the value of VCell_Max and allow the cells to balance without overcharging.
My question is, is there a way to enable and disable the charger in the multiplus 2 using this charge control contact in combination with a separate relay and a input on the Multiplus 2
