I have a Multiplus 2 3000 48V. I need 12V/50mA for an external circuit. The manual says that connector J pin 1 has 12V/100mA. Normally, its purpose is an external switch. Can I use this pin as power supply and connect this to my ciruit? What should I use as ground?
