If installing a 3phase system with Multiplus II (FW 502) and save the settings from the first Multi (L1) and loaded to the second Multi (L2), you can see different settings in case of checking the ESS assistant settings:
Image Caption
On the second Multi I couldn’t find the item for "cut off voltage".
One could assume that the first multi plays this role, but it is not mentioned in any documentation.
Are there any documentation regarding this topic or am I completely wrong?
Thanks in advance
