I have installed Venus OS large 2.93 on a RPi 4. As far as I have read, a relay should already be activatable in the settings.
Unfortunately I can't find an item called "relay" in the settings.
Can someone help me? Do I have to set or activate anything else to see this menu item?
And to which pin must the relay be connected by default?
Thanks!
Thanks Kevin Or do the whole thing like this, you don't have any problems because you only wire the pins that you need.
