jonathan-osborn avatar image
jonathan-osborn asked
Multiplus 2 48/5000 battery SOC issue
Hi All,
Im having an issue with my Multiplus 2 48/5000 that I cant work out.
The Multiplus alarms with a 'low SOC' and cuts out the inverter at 38% SoC. 40.9v . The SIMPBMS is still reporting OK to the CX via BMS-CAN. Low voltage cut off should be 39v. ( Im using two tesla packs in series) . The red low SOC light flashes on the Multi and the inverter trails the load off from the batteries and stops discharging at the levels mentioned above. I have been into the VE configure ( many many times) to set the battery type and low voltage cutoff levels, both under the 'inverter' tab and in ESS Assistant. I know the ESS assistant overrides the Inverter settings but it hasnt made any difference.
Any assistance or suggestions much appreciated.
Thanks
Multiplus-II
@Jonathan Osborn
If you share your settings with us another set of eyes may help.
Meine_Energiewende avatar image
Meine_Energiewende answered ·
That will not work. In an ESS System the lowest possible value is 41 volts. I've used 8 Tesla packs in a 2s4p configuration myselfs for some years.
37 volts is only possible if you use it as an island.
CU
jens
jonathan-osborn answered ·
Well that explains it. :-). Many Thanks for coming back to me.
