big-jez avatar image
big-jez asked
Is it possible to charge my invicta 12v 50amp with a solar panel? And if so could I use a 10 watt or 20 watt?
Solar Panel
Paul B avatar image Paul B commented ·
what is a
invicta 12v 50amp
some more info please this is a bit vague.
big-jez avatar image big-jez Paul B commented ·
It is my lithium 12v 50amp battery made by invicta
klim8skeptic avatar image
klim8skeptic answered ·
Invicta installation guide.
How fast do you want to charge your battery?
big-jez avatar image big-jez commented ·
I just want a fairly decent charge rate or if anything a basic trickle charge.
klim8skeptic avatar image klim8skeptic ♦ big-jez commented ·
A 20w panel would struggle to charge the panel at 1 amp.
Dont forget that you will need a charge controller that you can program for LifPO4 batts.
kevgermany avatar image kevgermany ♦♦ big-jez commented ·
Look at the charge rates specified by the maker and work back from there. You probably need about 100W to get a reasonable rate.
