When on the grid shore power and I test by turning shore power off, the inverter doesn't come on in 20 milliseconds like advertised. It faults, then will come on. Testing with 1 AC running with a softstart installed on it. My concern is that lag shuts off devices like my AC. If not in the RV and pets are there and power outage happens just briefly, it sets my AC to off, requiring manually turning it back on. Dragonfly said to Check Dynamic current limit and weak ac in setting. I am not sure if this is correct from what I have read. Any help here greatly appreciated. I have 4 100 amp Battleborns wired in parallel with 4/0 wire.
