Have questions about grounding in the system below.
The system is to be built in a motorhome.
Why should Multiplus be grounded in the negative bus bar?
And with what cable area in that case?
And which cable area should the ground cable to the Smart bms be?
None of these cables are longer than 3m.
For full view of the system
