I am currently designing the system for a camper. I have an old Quattro 24V/5000 with control panel, shunt, ... but no MPPT. So MPPT will be new ones. I will use also 3x batteries LiFePO4 with BMS integrated (24V, 230Ah).
To be more clear, below the design I made:
I guess, I have no way to connect the VE.direct output of MPPT to the system, correct (ie : no conversion from VE.direct to VE.net possible)? So, I may need to add a BT device for VE.Direct outputs if I want to monitor.
Also, any mistake in the design I made?
Note : for the 24V loads, it will go to a dedicated panel with a power on/off and all required fuses.
Thanks for your help.
Play3000
