tedka avatar image
tedka asked
Victron 3000va maximum load
I am electricity-ignorant. I want to know if using a 2000w electric kettle with a Victron 3000va can damage my batteries (4 Lithium 12.8v) or other parts of the system. Thanks.
MPPT Controllersbattery
The 3000VA Multi has a continues power of 2400W at 25°C, so no problem at this side.
https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-inverter-charger--800VA-5kVA-EN-.pdf
That are about 200A at 12V if your batteries can handle that should be in the datasheet.
If the rest of the system can handle that depends on if it is designed/installed properly.
tedka avatar image
tedka answered ·
Thank you very much. I may get back to you about this.
MPPT Product Page
MPPT Error codes
