Simon Coram avatar image
Simon Coram asked
Triggering a dump load
Ive just fitted to my boat 2x370w panels with a 100/50 mppt, all works well, batteries are fully charged agin by 8.30 in the morning. I am In the process of having a new calorifier water heater fitted which has a 12v/240v immersion element in. Watching this did you know video from Victron, it says you can set it up as a load dump to the heater
https://www.youtube.com/watch?v=dT89QtG2pS4
HAs anyone done it, or is it better/ easier to connect the 12 side to the batteries via a switch and switch on when i need it when I know the batteries are full. The 12v element is 300w.
Thanks
MPPT Controllers
Vance Mitchell avatar image Vance Mitchell commented ·
Can you let us know what other components you have in your system.
Do you have a BMV device? The built in relay can control a dump load at certain SOC.
It is reasonably easy to set a multiplus to dump AC2 when a certain SOC is reached.
If you can give us some more details, we might be able to give you more options and recommendations.
Simon Coram avatar image Simon Coram Vance Mitchell commented ·
Sorry for the delay in replying.
Ive got a BMV 712 with a Victron MPPT 100/50 and 7402 solar.
Mike Dorsett avatar image
Mike Dorsett answered ·
My MPPT 100/50 does not have a load output, but the BMV should have a relay that can be controlled by state of charge see https://www.victronenergy.com/upload/documents/Manual-BMV-700-700H-702-712-EN-NL-FR-DE-ES-SE.pdf section4.2.2
You could use this in it's inverted mode, with on at 90% soc and off at 80% soc to control a contactor (large relay) for your dump load.
