Skylla I permanently in storage mode.
Charges at about 25 amps at 24 when on it's own.
When Quattro is charging the Skylla does not charge at all. Its connected via VE Can and can be seen on the Cerbo. The rest of the system is 3x200 24volt A/h smart lithium in parallel with VE bus bms.
Need to have quattro and Skylla charging at full power to reduce run time of generator
The Skylla is set up for Lithium
