hello guys,
we have a Victron system with Victron LiPO4 batteries installed the system is operating with grid-connected to it and in ESS mode, I made all the configuration with Ve Config, and I have one concern that is about the battery SOC and when to shut down the system depending on this.
there are two parts in ve configure related to the battery, the shutdown on SOC and the DYNAMIC CUT-OFF, I actually don't get the difference between them or which one will overcome the other.
I know that the cut-off is related to how fast the batteries are being discharged and to prevent continuous high discharge but I would like to shut down my batteries at 20 % soc whatever the discharge current is so if I set SOC shutdown in ve config to 15% with this overcome all the dynamic cutoff settings and shutdown at the 20 SOC%?
and how will this SOC level be calculated I already have Victron smart lithium batteries with VE-bus BMS and GX-color control that is showing the SOC of the battery, will the system consider this reading all I should install and extra BMV.
I attached two photos of ve configure part dynamic cut off and SOC shutdown parts
