When the new MultiPlus-II 2x 120V was announced, I thought it would do power share on both lines. But, reading the manual, it appears to only do line 1?
PowerAssist takes the principle of PowerControl to a further dimension. Where peak power is so often required only for a limited period, the MultiPlus-II will compensate insufficient generator, shore or grid power with power from the battery. When the load reduces, the spare power is used to recharge the battery (available on L1 input only).
This is what my current GoPower inverter does and it's essentially useless in an RV installation.
Can someone validate / clarify this?
Thanks!
-chad
