I have 2 Orion Smart TR 12/30 on my boat. Each is connected to it’s own AGM start battery with alternator input from separate engines, and each charges the single house bank. I have the ignition from each engine connected to the “H“ input on the Orion. Nothing is connected to the “L” input. This was installed 6 months ago and was working as designed. Recently, however, the Orions will charge regardless of the ignition voltage. As long as the start battery voltage is sufficient (I also have a shore charger for the start batteries), the Orions will begin charging the house bank. I have tested even with the green terminal connector removed, and the Orions will still charge. Not possible according to the manual. Any ideas? Am I missing something?
