metermee avatar image
metermee asked
Connecting EM24 Ethernet to Home Assistent
I have no Victron devices at home at this moment however would like to know the consumption and history power usage over time for my 3 phase powerline
Victron states its easy to connect there devices to a home assistent ( https://www.youtube.com/watch?v=9vDSRh6rmis)
However i cannot find any info how to read data from my home assistant directly over my ethernet network from the Victron EM24 Ethernet?
Is it possible to read directly data from the EM24 with mqtt into home assistant?
em24
michaels-1 avatar image
michaels-1 answered ·
Hi Metermee,
I also have only the EM24 Eth. and had the same problem and found you question here with no answer.
I managed to integrate the EM24 with Home Assistant.
Modbus is part of Home Assistant and you just need to configure like this (which took me several days to find out):
My config looks like this:
open and edit:
<< /config/configuration.yaml >>
modbus:
- name: hub1
type: tcp
host: 192.168.0.123
port: 502
sensor:
- platform: modbus
scan_interval: 10
registers:
###. EM24-E1 ###
- name: L1-N
hub: hub1
unit_of_measurement: V
register: 0000
register_type: input
count: 1
slave: 30
precision: 2
scale: 0.1
- name: L2-N
hub: hub1
register: 0002
count: 1
slave: 30
precision: 2
scale: 0.1
Please let me know if it works for you.
BR
Michael
Energy Meter Manual EM24 RS485
