Uwe Knöfel avatar image
Uwe Knöfel asked
2 smart shunts, which to use as battery protect ( if at all )
Hello, I have 2 Smart Shunts in my camper :
One for the car AGM battery, one for the 158Ah LiFePo Camper Battery, monitoring and reporting via GXS works great.
Main purpose is to monitor voltage, charge & discharge and finally SOC.
Now I ‚detected‘ that I could define one of the shunts as battery protect of choose automatic or none.
Here my 2 questions :
1) the two shunts have the same name in that screen, so which on is for which battery ?
I could unplug one and chose the remaining one .. but will this order stay after a reboot, new firmware ?
2) does it make any sense at all to define one of these shunts a battery protect ?
My LiFePo does not seem to be DVCC compatible and the car battery is AGM.
Regards
Uwe
SmartShunt
What do you mean by "battery protect" ?
The smart shunt can only measure voltage and current. It can't switch on/off loads or charging.
Uwe Knöfel avatar image Uwe Knöfel Matthias Lange - DE ♦ commented ·
Hi Matthias,
The idea came just because the Shunts are ‚offered‘ is the GSX remote console to be used as battery protection.
Same as DVCC, which is offered to be switched on/off.
I would think the GSX system is ‚clever‘ enough to display these options only, if the ‚offered‘ system are capable to perform this functionality.
But maybe my expectations are a bit too high at this point.
