Has anyone managed to install Venus OS on a 3 A+? I can see that the B and B+ is supported but can't find anything at all on the A+ model.
I'm looking to set up and connect the Pi to a BMV-712 and/or a MPPT, does it require connection via USB/VE.direct or is it possible to connect via Bluetooth instead?
I guess one major disadvantage of the A+ model is the lack of RJ45-port which probably makes the installation a bit harder. When installing Raspbian for example, you have the possibility to config the wifi before booting it up, is there a similar way on Venus OS to make it connect to wifi automatically?
